021 upgrade
leecopland
Hi Folks,
Long time since I'm been on here, so a question on an 021 I picked up recently. I'm wondering if I could put an 023 P&C on it and still use the exciting plastics ?
Warm regards,
Lee
Hey welcome back!! You can usually do that, but compatibility with the existing plastics depends on the specific parts and fit. Might be real good to check with the manufacturer or a dealer to confirm if your current plastics will work or if you'll need replacements.
What I've seen, yes the 021 and 023 share most of the same plastics. The 023 P&C should fit, just double-check port alignment and crankcase fit before buttoning it up
