Echo CS590 VS Husqi 460 Rancher
Ronie_
Upgrading my saw and can't decide between the Echo CS590 and the Husqi 460 Rancher
the Echo is $100 cheaper right now ($370 vs $470). I wonder is the Husky significantly better, or am I just paying for the brand?
I’ve got 12 big trees to drop, then it’s just light duty after that. Is the Echo good for this?
The Echo has plenty of power for big trees as long as you keep it well maintained, and saving that hundred bucks helps, especially with fuel and wedges. The Husky might feel better overall, but the Echo won't let you down for your needs.
I used to have an Echo and it handled several large trees with no issues. If you're just doing some occasional cutting after taking down the big ones, that $100 you save is worth it.
Last time, I went with a Rancher and it felt more robust on heavier wood, but the Echo held its ground too. If you’re tackling 12 big trees followed by lighter work, the Echo sounds like a reliable choice that won't break the bank.
The Echo CS-590 Timberwolf is 4 hp vs the 460 Rancher' 3.6hp. The Echo is built on a professional magnesium chassis while the Rancher is plastic. I have Rancher 450 & it's been a good saw. However, if I were to do it over again, I would have got a better 50cc saw. You will not regret buying the Timberwolf!
I appreciate the insight. It seems like the Timberwolf is certainly worth a look.
