Keeping your saw in good shape when you're working in wet muddy conditions
Alan
Administrator
Staff member
Admin
Moderator
When you're out there cutting through the muck, it’s not long before your saw starts to collect all sorts of gunk. What are some real-world tips, quick clean-up methods, or simple habits you rely on to keep your chainsaw running smoothly without having to stop every few minutes?
Make it a habit to blow out the air filter every time you fill up, it's quick with compressed air or just give it a good tap. Also, clean the bar groove of sawdust and check the chain tension. A dirty saw can overheat and slow you down, so regular cleaning is better than dealing with breakdowns.
Always keep a small brush handy for quick cleanups while you’re working.
Make sure to clear the clutch cover vents to prevent overheating.
Remember to flip your bar regularly to avoid uneven wear from dirt piling up.
After you finish cutting, run the saw at full throttle for a few seconds to blow out debris from the clutch and cooling fins. Avoid cutting in dirt, as it quickly dulls the chain and clogs everything up. These little practices help your saw perform well without needing constant maintenance.
Blow-out compressed-air cheat code: Get a cordless tire inflator on whatever cordless tool platform you're on. Usually comes with a concentrator tip. Not like shop air, obviously, but in the field it'll do an adequate job blowing out the air filter, bar slot, inside the clutch cover, etc.
Great habits all around. The cordless inflator tip is especially clever for field cleanouts, super practical when shop air is not an option. Little routines like these really keep saws running happy.
I blow my saws off and out after each use, espeically under the clutch cover.
Fine tip air gun works the best for nooks and crannies.
    13.5 KB
Be careful blowing out those air filters
Most good air filters have flock on them
Knock them off in the field, wash them in straight gas or use brake clean when in the shop
Blow only hard enough to dry them.
Air filters have to be pretty dirty to affect saw performance.
In fact Stihl cut off saw filters are at peak performance when they have some dust on them.
In tips to prevent overheating.
What I wrote there pretty much covers the field but if it is really wet and muddy
I give it a miss but if you are logging and have to work I would say a good sharp
axe is a good friend. If the trunk still has bark where you are going to cut clean
the bark and as much dirt as possible. A small stiff half brush is a good tool as well.
I have a friend that gathers firewood with me who will cut through anything and everything.
I will probably have to sharpen my chain once a day and he is about 3 or 4 times plus
he will do 2 to3 chains to my one so it's a no brainer keep your cut area as clean as possible.
The biggest thing is keeping the chain out of the dirt whenever possible. Mud and grit will dull a chain faster than wood ever will. I also make a habit of popping the side cover off at the end of the day to clean out packed debris around the sprocket and bar groove.
