Checking chain tension on your saw
Alan
Administrator
Staff member
Admin
Moderator
You definitely don’t want any surprises while you’re working. What’s your favorite way to check that tension? Do you rely on a finger pull, a quick visual check, or a twist trick that keeps the chain snug without going overboard?
I usually stick with finger pull and a quick glance. If it lifts easily but still holds the bar tightly, I’m satisfied. I’ve dabbled with twist techniques, but I prefer simple checks to avoid over-tightening and burning out bars
I rely on feel more than strict rules. I do a finger pull, give the chain a spin, and that’s usually enough. If it moves freely without drooping like spaghetti, I know it’s snug enough for the job.
Yeh finger pull for me I was taught in the sawmill I worked in as a young guy as long as the bottom of
the drivers were not showing, but that was on the bars that never sported sprockets. I think on sprocket
bars you can run a bit tighter than that but over the years I have worked chainsaws it is more or less
a feel thing and as long as the chain spins freely.
Sounds like finger-pull and feel are the dependable methods.
Experience at work. That intuitive feel is key to making sure chains run seamlessly.
