562xp mark ii big air kits???
treeelzebub
Is there a big air kit available. My technician told me that it is taking 15 pounds of vacuum to pull air through the uptdated air filter. That it should be around 7. Any one know of a solution? Thanks
Joel McMullan.
That's a significant vacuum drop, probably a restriction somewhere in the intake!
Have you tried running it briefly without the air filter to se if the vacuum reading improves?
I'm thinking the updated filter isn't compatible with your saw.
You can also check if there's an issue with the filter housing or intake boot.
A big air kit could help reduce the vacuum, I'd recommend looking for high-flow intake kits or performance filters to improve airflow
The design could be restrictive, so @CutTheNoise might be on to something. Try without the filter and see if it does any better. Don't run it for too long thouh. If that's the case, you can look into read beard, I think they have an upgraded filter
Joel McMullan.
Hey, Joel. I don't know where you can get a big air kit to be honest. Agreeing with @Firingorder and @CutTheNoise on the troubleshooting stuff tho. Best of luck and update us here on anything.
