Carb tuning, ear or tach?
Timbertrail
Over the weekend I was tweaking the carb on my saw and I found myself in a bit of a pickle, should I trust my instincts on the sound or should I whip out the tach for some precision?
What do you typically do when tuning carbs? Any handy tips for balancing speed and smooth running without losing your mind?
I’ve had my share of experiences with my old chainsaw. Initially I tuned it by ear just like my dad showed me. But after one unfortunate incident where I ran it too lean and ruined a piston I started using a tach. Now I listen to the sound first and then confirm with the tach to make sure I’m doing it right
I tune by ear as some of those tachs I am not to sure how accurate they are.
I have always got the low jet were it is running nice and smooth then on the high jet
give it a burst of full revs take it up to peek revs and them back it off and leave it a bit rich.
When you hear the motor 4 stroking this means it is a bit on the rich side.
I have always tuned this way and never had a problem yet.
Yeah, most people just tune it by ear and then double check with a tach.
hmmm, you should always use both your ear and the tach, but for different things.
use your ear and instincts for the low-speed L mixture. You want the engine to idle smoothly, accelerate cleanly without bogging, and sound crisp.
use the tachometer for the high-speed H setting. This is important for engine safety!
Great advice. It strikes a perfect balance between intuition and accuracy. A fantastic approach to ensure everything runs smoothly and safely.
