A tube on the carburetor is broken and the gas runs out of the saw when sitting. Saw was running great until this happened. My repair shop could not fix it. I can not find a complete carburetor. Any suggestions?
Hey, sorry the repair shop came up empty on that one. Husqvarna carbs can be finicky but there's usually a fix. Have you checked if you can source just the tube itself or looked at carburetor rebuild kits for your model?
Which tube the brass one going into the carb I suspect. Most are just pressed in
so if it is leaking around there you may get away with cleaning it and using a
really good high powered glue like Araldite Glue or something similar
