Deleted member 111
- May 3, 2025
The E-Go or EGO.
I'm guessing the saw got its name much like electric bicycles did when those then got called E-bikes. So this saw just goes with the push of a button without having to pull a cord to start it. I was skeptical at first. I already had/have have a Husqvarna and two STIHL gas powered saws. I bought this quieter electric saw to use around the house and also in doing trail work in my local city park. Neighbors are less skeptical if they don't hear or smell something and its perceived to be less of a fire danger.
I own the 18" home version (not the commercial one).
I have taken the saw apart almost completely, and put it back together. At one point, something got stuck in the chain, and it broke the plastic in the casing. After using it that way for many years, the inside started to get full of sawdust. So I took it apart, removed all the sawdust and put it back and after sealing with epoxy putty that hole from both sides, I put it back together. Like I said, I was very skeptical of the saw at first. I have used it for at least four years, gone through two chains, and also just abused it. And the thing just keeps working. I bent the bar and I just straightened it out and it keeps working. I like its running light for longer work days that go to dusk. The only thing is the battery. I own five. The reason is that sometimes there's really large deadfall that requires many cuts to unblock a trail. One 5 AH battery is almost about a tank-worth of gas. So traditionally, I will sharpen the chain after I go through one battery.
If anybody has any questions on this saw, feel free to ask.
