Hi all! Gradually over the last couple years, my 011 saw bar oiler flow has gotten excessive which throws somewhat visible oil off the bar tip and leaks out the feeder hole behind the bar. Have been thru the diaphram pump looking for problem areas, replaced the oil filter there, but other than that, it all looks good.
Question- the outlet hole behind the bar looks to be about .20” dia or so. Is it possible that there would-could be a missing nozzle with smaller hole to limit flow there? Any ideas or help would be greatly appreciated.
Thank you!
Thank you!
