Echo 550evl replacement parts
Aaron Cooper
So I have an echo 550 EVL chainsaw that I am having no luck in finding a ignition coil for seem the part has been discontinued and I can't find what part to replace it with nor have I had any luck finding a used one in my area my question is if anyone knows where can I find replacement parts also here is the part number I've been looking for A411000150
    1.1 MB
    753.5 KB
Finding an ignition coil for the Echo 550 EVL (part #A411000150) can be hard since it's discontinued. But it looks like it's available in eReplacementParts.You might also try Chainsawr or keep an eye on eBay for used parts.
Try online auctions or specialty small engine repair shops. Another option is to look for compatible replacement parts. Some parts from other models of Echo chainsaws might fit the 550 EVL, or there may be aftermarket brands that produce a compatible ignition coil. It can be worth calling a few well-known small engine parts suppliers to see if they have a cross-reference for the part. Sometimes a part number from a newer model will work with a little bit of modification.
I agree with @RocketSurgeon525! The part you are looking for is not available in eReplacementParts. Here's the Part Number: 15662618330
You can try checking with Ace Home Center. They have very limited stocks available.
https://allendaleace.com/p/ignition-coil-ech15662618330
