How far can I push it?
Thinking about swapping to a 24" replacement bar and chain on my Stihl MS271 but heard it could strain the engine. Is this a real risk or can it manage without turning into a smoking mess? I'm looking at Stihl MS271 replacement bar and chain options but safety is my top priority. Any advice before I commit?
50cc saw, 18" bar.
Used to be 50/55cc used a 16" bar. I realize bars are longer with newer saws, thus 18" bar. IF and I do say IF you needed it for 1 tree (your own yard) 24" bar you could get by. GOD thats awful long for that little saw.
Steady diet of a 20" bar for that saw, I'd be saving $$weekly for a new saw.
MHO
Swapping to a 24" bar could strain the MS271 if you're pushing it hard for long periods, so it's better suited for a 20" bar but safety first, so stick with a lighter bar for smoother operation
Thanks for the advice everyone. Seems like a 24" bar might be more than my MS271 can handle for regular use. For safety and smooth operation, will stick with a lighter bar and save the big jobs for when I upgrade to a bigger saw.
Yeah, I've decided to hold off and stick with something that won't push the MS271 too hard. I'll keep it around 18" for now and maybe look into a 20" if I'm only doing light cuts. Planning to upgrade to a bigger saw next season if I start tackling larger trees more often.
It makes sense to pair your saw's capabilities with the tasks you need to tackle. The MS271 should do a great job with 18" cuts, and if you're looking to make light cuts, a 20" bar is a solid upgrade. If you plan to take on larger trees next season, it would be wise to upgrade to ensure you have the right tool for the job.
I completely agree, the MS271 does a great job with an 18" bar, and using a 20" bar definitely adds some extra versatility.
From experience MS271 performs significantly better with a 20" bar. A lighter setup not only enhances safety but also boosts efficiency.
Does the 20" bar slow things down much on thicker wood? And when you upgrade, are you thinking pro-level like the MS362 or something bigger?
The 20 bar is good enough when I'm cutting small stuff, but the MS271 bogs down in thicker wood. I'm thinking of getting an MS362 next time I upgrade.
The motor just isn't sized for that much bar. You'll get chain speed drop, more heat, and faster wear. If you really need 24", better to look at a bigger saw than force the 271 into it.
I agree with everyone. 18 inch maximum
Also puts too much strain on bar mounting area. The studs are screwed into plastic ( or whatever Stihl calls it).
I've run a 20 inch on my MS-280. Not sure how much smaller a 271 is. You might eke by with a 20"-er. Joining the dog-pile, definitely not a 24.
