How to verify ignition timing on older saws
Alan
Administrator
Staff member
Admin
Moderator
When you fire up an older saw and it just doesn’t feel quite right, what’s the best way to check the ignition timing without diving into a full teardown? Share your go-to methods, tools, and any classic tricks that still do the job!
Fired up a friend’s older saw that sounded pretty sad.
My go-to move is to spin it slowly, check the marks, and use a timing light if necessary.
It’s surprising how often just a quick look at the flywheel key or stator alignment can fix the problem without needing to dig into the engine.
There was this dusty old 346XP I picked up, thinking, 'How bad could it be?' Well running a simple test light across the plug while slowly turning the engine showed me more than I was expecting. Those strobe timing tools are lifesavers and sometimes just cleaning the points gives you that immediate 'ah that’s better' feeling.
Had this old 362XP that really struggled in the snow. What I usually do is pull the plug, turn it by hand, and keep an eye on the timing marks. Having a good strobe light makes things a lot easier, and just taking a quick look at the flywheel key can save you from a major teardown headache.
If you get problems with an older engine misfires and lack of power your points and capacitor can often be the culprits rather than the timing.
Pitted points = stone them off clean. If they pit again soon the capacitor is often the culprit.
A distinctly blue spark is usually a sign of a faulty capacitor.
A capacitor of another make will still do the job.
Example a Bosch capacitor on a twin cylinder Laverda 750 bike in the 70's cost about £18 each a Lucas capacitor that fit a morris car cost about £0.50 at that time and worked perfectly.
Great tip. It's so easy to miss those points and caps, and that blue spark trick is incredibly useful.
I wonder how many people have ever set the points correctly on an old saw? Used a dial indicator and powered test light to set the points and timing?
Still have the tools. Not much need for them now.
Ha! Those skills deserve to stay in use.
I agree. I welcomed the technology as well but at 72 years young I still like the odd antique to play with occasionally.
Ha, bringing that S10 back to life is what really matters.
