I just bought this MS 250 about two weeks ago, did some break-in time on it, and cut up a couple of small trees. Running just fine. Took it out again two days ago and it refused to start. Went to pull the factory spark plug to check it out, and found it so dang tight that a breaker bar was needed to break it free. Didn't check the gap, but did determine that there was spark. Not wanting to dig into it any further since it was just purchased, I took it back to the small engine dealer I bought it from. Fella took it to the back room for a few, and returned with the problem fixed. The spark plug gap had somehow closed down to the point that it wouldn't run. NOW... How did that happen? I figured that the only way possible is that the piston had made contact with the electrode. It ran fine before, and I told him that. He said there's no way that the piston could have hit the spark plug. So, anybody have a possible explanation? The clearance between the piston and the plug is between .02 and .03 MM according to the information I could find. Thats darn close as it is. Something closed the gap on that spark plug is all I know. But what?
