Post-Tune Chainsaw Safety Checks
fileandsmile
After tuning the carb on my chainsaw, I’ve begun doing some quick safety checks before I start cutting. What checks if any, do you run after adjusting your saw, like the chain brake, idle, and throttle response?
I always give the chain brake a try, check if the engine idles steady, and ensure the throttle springs back like it should, it's all about keeping things safe and running smoothly.
The biggest risk after tuning is the idle being set too high, so that's where I always start.
I do c hain stop check, chain brake test, also throttle response check. Snappy throttle response means your low speed L screw is right. If it bogs or hesitates, it's too lean
Your checklist is solid. Kicking things off with idle makes perfect sense and I love how you linked throttle response back to the L screw. Thanks for sharing such clear and practical advice.
