Most muffler mods typically involve either opening up or adding an exhaust port to enhance airflow. Sometimes, a small deflector is fitted to help direct the exhaust gases. This process usually requires drilling or cutting the outlet and smoothing out any rough edges. Since this adjustment can lean out the fuel mixture, you’ll often need to slightly enrich the carb settings, particularly the high-speed jet, to avoid overheating or engine seizure.
