scott yunginger
- Jun 16, 2025
Hello Everyone!
I am new to forum but have visited it many times to get valuable information.
I picked up a used echo cs 301 to use strictly for limbing branches , it started up and ran when I got it home, but after warmed up started wanting to die, got worse, replaced plug, same ,removed carb and ran it thru sonic cleaner, better briefly,
Then would not even start, checked spark, it was good, checked compression, is right at 125 psi.
Carb actually looked pretty clean, top and bottom gaskets/diaphragm etc. look good. Have not replaced fuel filter yet, cleaned it, looked good,
Does not even pop now, paid $80, ok with ordering some parts but not sure on OEM carb yet, should I just order a cheap knock off carb to try? Primer bulb seems to be working.
Sure seems like a nice little saw but growing tired of it quickly.
I would sure appreciate some input on this issue.
Thanks!
Thanks!
