I was brought an ms251c to check why would not run. They brought a new carb and plug. I took one look at this saw and immediately saw a machine that had been run with no maintenance. Had to scrape saw dust and oil debris out of everywhere. No filter in tank ,bar discolored, sprocket worn down to core, pump drive melted, and no spark. When I removed the old carb had to scrape the filter screen clean ,was completely clogged. Did an engine vacuum and pressure test and both failed. Customer said fix whatever it took. I immediately saw was going to be a challenge. After thorough cleaning and many new parts still have one problem I seem to either missing or this saw is haunted i put a new coil in also. Neon tester shows good coil but still no spark. I have tried everything still no spark. Any suggestions?
Fmac
Fmac
