I did some exploring, and here’s what I found:
You can definitely mount a 20" bar from a Husqvarna 455 Rancher onto an Echo CS-4910, provided the bar mount is a match. Both typically use 3/8" pitch chains, but it’s wise to check a few key details:
Here are the compatibility checks to keep in mind:
- Bar mount pattern (stud spacing and slot width)
- Chain gauge (.050" or .058")- Chain pitch (3/8" standard)
- Oil hole alignment
The CS-4910 is rated for bars up to 20", so it should have enough power, though the cutting speed might be a bit slower than ideal. Just make sure the bar fits well and that the oil hole aligns properly. Before you buy, measure your Echo's bar studs and compare them to the Husqvarna bar specifications.
