Hello Everyone
I am a new member,
I live by Brookings S.D. live in the country, I have browsed thru the forum many times over the past few years.
I have a Woodstock soapstone wood stove in house and a wood stove in my shop.
My main saw is a Stihl ms 361, great saw, but recently purchased an echo cs 301 for limbing, last night Ijoined and put a post on forum about issues with it, I want a light weight capable saw for limbing branches once tree is on ground, if I cannot get the echo up to speed will be on the search for a new saw.
Great knowledgeable group here for sure!
Thanks
I got a Ryobi 40volt battery 14" saw and it is unreal! A little heavy but not as heavy as my 18" Husky!
Hey Scott
Well you already have the MS361, might look at the MS261 with 16" bar and convert it over to 3/8" .050" chain, so the same sharpener will work for both. I would look at one with your Stihl dealer and most would or should convert it for you, rim sprocket, bar, and chain is all you need.
I converted mine to 3/8" .050" as well as adding the full length clutch cover.
If you cannot get your echo lined out
