I know this is an old post but I'd avoid using Seal-All on the fuel line itself. Engine vibration will eventually crack the sealant and an air leak there can lean out the saw and cook the piston. The correct method is to obtain a properly sized diameter of quality ethanol-resistant fuel line for a tight press fit seal. What was the outcome of your project?Trying to restore a mac 7 - 10 a going to use seal all on gas tank gasket as someone had it the tank off I suppose, and I am going to use a new gasket, and fuel line. Should I use seal all on the fuel line where it goes into the case?
I'm with @Vorhi-heesy1985, definitely don't use Seal-All on the fuel line where it goes into the case.Trying to restore a mac 7 - 10 a going to use seal all on gas tank gasket as someone had it the tank off I suppose, and I am going to use a new gasket, and fuel line. Should I use seal all on the fuel line where it goes into the case?
