Old saws vs new saws in the cold
Thornpath
You know those frigid mornings when one saw fires up without a hitch, while another barely wants to start? How do old and new saws perform in cold weather and which ones you trust when the temperatures fall.
I find my old saws typically start better in the cold than my new stuff does. I have a lot of old Echos and they have always been good starters even when they sit 6-8 months
Aside from the EPA issues and limitations placed on newer saws, I have not noticed a real difference as long as you take care of your saw, keep it tuned, and use good fuel. Here in Wisconsin, I've used mine in all weather conditions. I do ensure the sun/snow slider is correct for the conditions of my Echo's. Usually I get it barking at the 2nd or 3rd pull and started on the following. I do keep them along with all my tools, tractors and toys in a heated garage that helps.
Some newer saws have fixed carbs so they can be a problem.
With adjustable carbs you can open the jets a little for cold weather & my Stihl pro has a winter shutter but I do not cut much in the winter so I have never used it.
Seems like you’ve got your setups just right. Making sure everything is well-tuned and properly stored takes care of a lot, especially when the temps start to fall.
