B Big Mike New member Joined Oct 7, 2025 Messages 3 Oct 7, 2025 #1 Can someone tell me please what are the initial carb settings on a Remington 754 after a carb rebuild please. It has a Tilotson
sharpedge Active member Joined Aug 31, 2025 Messages 42 Oct 8, 2025 #2 Set both the H and L screws to 1 turn out. Once the engine is warm, adjust them as needed.
Cuttingranger Well-known member Joined Apr 29, 2025 Messages 51 Oct 10, 2025 #3 Also make sure the idle screw is set to keep the throttle plate slightly open for easy cold starts. When you put it back together, check the diaphragm and gasket to prevent tuning problems.
